Run a Script or Script Command
This event action is designed to execute a custom script of script command within the current event. The action may be accessed by selecting Run a Script or Script Command from the action group menu. Simply select the script (or enter the script command) you wish to execute or build your own script.
Example
Expanded
Settings
Setting
Description
Script
Select an existing script to run from this action
New Script
Enter new script name when creating new scripts
Sub or Function
Use this field to enter an immediate script function
Parameters
Enter script parameters (if required) for your script
Immediate Command
Tick this box to run an immediate script command
Wait for script to finish
Tick this box to ensure the selected script completes before executing additional actions
Only run one script at a time
Tick this box to prevent multiple scripts from running simultaneously
Creating New Scripts
  1. Enter a name into the New Script field
  2. Click EDIT SCRIPT. The script creation screen will appear
  3. Enter your new script and click SAVE
Editing Existing Scripts
  1. Select existing script from Script drop down menu
  2. Click EDIT SCRIPT and make your edits
  3. Click SAVE
