Z-Seer Installation
Instructions on installing and registering Z-Seer+ on your Windows PC.
Software Installation
Download the Z-Seer+ installer from HomeSeer Downloads page and launch it on your PC. Follow the prompts to complete the installation and a shortcut to the program will be added to your desktop and start menu.
Latest version:
Registration
  • After opening Z-Seer+ for the first time, you will be prompted to register it. If you close this by accident, you can always get back to the registration section from Help > Register License...
  • If you are a HomeSeer veteran and own a copy of the original HS2 version of Z-Seer, then you can enter your older license along with the upgrade license you received. You can always recover licenses from here.
  • If you do not have an HS2 Z-Seer license, then you will simply want to enter the license info you purchased in the License ID and License Password fields, which you should have received from licensing@homeseer.com.
  • If you are an HS3PRO or HS4PRO or HomeTroller PRO owner, Z-Seer+ is included with your PRO version of HS3 or HS4. Just use your HS3PRO or HS4PRO license to register your copy of Z-Seer+.
