Z-Seer+
Articles about using Z-Seer+. Purchase Z-Seer
  • Z-Seer Overview
    Z-Seer+ is a software tool that's designed to help diagnose and treat the health of a HomeSeer system's Z-Wave network.
  • Connect Z-Seer to HomeSeer
    Z-Seer+ is a Windows application that may be used locally (on the same system as HS3) or remotely, via a network connection. Use the appropriate procedure below to connect to your system and selecting your Z-Wave network.
  • Menu Bar Functions
    As with any program, there are essential functions found in the menu bar in the top, left-hand corner of the window. Each section and the functions within are explained below.
  • Working with Z-Seer+
    If you're using Z-Seer+ for the first time, here are a few suggestions to help you get started.
  • Z-Seer+ FAQ
    Frequently asked questions about Z-Seer+.
