Zee S2 System Restore and Resetting the Network
Zee S2 System Restore Procedure
Use this procedure only after the 911 features do not fix your problem and you have contacted HomeSeer support. This procedure will wipe your existing data. Make sure to back up your HS3 configuration by following this guide.
  1. Plug in a monitor and keyboard to your Zee S2.
  2. Restart your Zee S2 and wait for the prompt that says "For recovery mode, hold Shift".
  3. Once the restore loads, a screen will load shortly allowing you to select the Zee S2 Factory Image.
  4. Select the Factory Image and click Install at the top left.
  5. Once finished click OK and your Zee S2 will reboot.
Zee S2 Reset Network Settings
  1. Connect a keyboard to the unit and reboot your Zee S2.
  2. Type R or r and then press Enter when the light turns yellow.
  3. If the light turns blue, your settings were successfully reset.
