Skip to main content
Skip table of contents
HS4 Beta Release 4.2.22.86
After testing completes, this build will be released as 4.2.23.0.
As with all Beta releases, make sure you back up your system before installing this Beta!
Manual Install
Windows
Linux
Download HS4 Windows
Download HS4 Linux
HS4 Changes from 4.2.22.78 to 4.2.22.86
  • Added support to copy a card from the cards list
  • Added support so upload cards in zip format, see docs here
  • Notifications older than 365 days are automatically deleted, even if they are unread
  • Internal cards can now be added from the Add Card dialog
  • Removed “Add Dashboard” and “Poll Devices” from dashboard menu if dashboard page is not displayed
  • To edit a card, click on the card then the edit menu appears (allows for moving very small cards)
  • Allow scrollbars when dashboard is in fixed resizable mode (edit and non-edit, with or without navbar)
  • Allow page to resize in dashboard edit mode
  • Color picker now saves color when used on virtual devices
  • Added a second save option for saving dashboard card format to only cards of the same type
  • Gauge card now uses system locale for displaying values
HS4 Changes from 4.2.22.69 to 4.2.22.78
  • Fixed issue with events disappearing after a power failure
  • When restoring files from a back up, the restore will skip bad files as opposed to failing
  • Extended timeout on update countdown page
  • Add LAN MAC address to about page for setting up IP reservation
  • Fixed missing controls button in list view
  • Fixes for Alexa/Google control
  • Added search phrases: “alexa”,”google”,”voice”
  • Fixed large gap at top of dashboard when using fixed dashboard mode
  • Updates to gauge card: Added support for decimals, added # decimals settings, fixed % for color display
  • Fixed button card layout, added option to add padding at top of card
HS4 Changes from 4.2.22.68 to 4.2.22.69
  • Events configured without a TO email address would not save. The TO address is not required as it will use the default in setup if its missing
  • Fixed All On/Off toggle on multi-feature card
  • Fixed unable to select a feature on the gauge card
  • Buttons are now spaced evenly on the buttons card when the card is stretched
  • Added ability to resize the entire screen when using the Fixed Resize layout (experimental)
HS4 Changes from 4.2.22.66 to 4.2.22.68
  • Fixed issue where Alexa discovery was not discovering new devices
  • Fixed “Controls” button being repeated in grid view and dashboard views
HS4 Changes from 4.2.22.65 to 4.2.22.66
  • More fixes for errors with HS3 plugins
HS4 Changes from 4.2.22.64 to 4.2.22.65
  • Fixed errors with HS3 plugins
HS4 Changes from 4.2.22.61 to 4.2.22.64
  • Fixed issues with some plugins not loading or settings not displaying
  • Added the ability for dashboard screens to stay active if not interacted with
HS4 Changes from 4.2.22.59 to 4.2.22.61
  • Fixed device cards not updating device status
  • On button card, fixed the ability to set the button label text size and removed the CSS that kept the label all caps
  • Fixed an issue where resizing a card and then editing its setting, lost the resize
  • Fixed the “all on/off” button not displaying on multi-feature card
HS4 Changes from 4.2.22.58 to 4.2.22.59
  • Fixed errors with HS3 plugins either not loading or displaying an error when used
  • Fixed device card not honoring new order of features after editing the card
HS4 Changes from 4.2.22.41 to 4.2.22.58
  • New Add Card dialog
  • When copying a device card, last change was not copied
  • Fixed issues with navbar menus displaying under cards
  • Pulled out common code from cards to simplify them, card_text to be used as a base for new cards
  • Merged in changes required for updated MyHS features
  • Status text card can now display status text or device value and display device last change, added bold option to text
  • Added dashboards to user access settings in setup
  • Added ability to share dashboards with other users
  • Cleaned up display of multi feature card
  • Cards auto size properly when changing dashboard display mode
  • Fixed layout issues when card HTML is updated after page is loaded
  • Card updates optimized with less callbacks to HS
  • Changes to button card for use with touch devices
HS4 Changes from 4.2.22.37 to 4.2.22.41
  • Added text color and background color to button card
  • Added button to select droplist on feature card
  • Added bold and suffix text to value on button card
  • Fixed notification card so it now adds the summary text, added bold to notification text
  • Fixed issues with multiple feature cards on the same dashboard, added padding in case a scrollbar appears, added background color to title, title no longer scrolls
  • Gauge card can now reference any feature
  • Changed background of pop-up edit to blue, text white
  • Changed exit edit mode icon on navbar to RED to indicate that edit mode is active
  • Added + icon at lower right of screen to easily add cards
  • Added custom title to single device status card to override device name
  • Added “Open URL” action to button card
  • Added new iframe card to display a web site in an iframe, thanks to ksum for donating his work on the card
HS4 Changes from 4.2.22.32 to 4.2.22.37
  • Added multiselect for feature selector on multifeature card
  • Added text color and bold to button card
  • Added text bold and update interval setting for text card (in case text is a script)
  • Added device selector to thermostat card
  • Features on device now use drag/drop to reorder features displayed
  • HS backups were including an old html.zip file, if it existed, this old file is now removed
  • Fixed error if a feature was added twice to the multifeature card
  • Forecast card now includes correct coordinates
HS4 Changes from 4.2.22.29 to 4.2.22.32
  • Requested changes to how Windows updates are disabled
  • Fixed some formatting of features on the multi feature card
  • Fixed thermostat card now allows for adding missing features
  • Feature name can be hidden on the multi feature card, fixed setting that controls display of device name, text alignment changes
  • Added icon and ability to add status only features to multi feature card. You can now disable the “All” toggle
  • HS-2094 Fix for HSEvent not being called for some bulk actions
  • HS-2064 Fix "Auto Discover Known Camera Types" setting turning off after HS4 restart.
  • HS-1904 Keep current color when opening a color picker from the devices page.
  • Added background image and size settings to button card
  • Fixed location text (size and location) not copied when saving display settings to all cards
  • Added parse_text function to text card to allow the display of scriban code to the Text card
  • Fixed "show last change" setting not saving
  • Changed status text and status image cards to update divs when status changes (as opposed to entire card)
HS4 Changes from 4.2.22.27 to 4.2.22.29
  • Added ability to set card format defaults to dashboard settings
  • In Fixed Resizable layout you could change the edit dialog
  • The arrows are removed from the edit bar in fixed resizable layout since the cards are manually positioned
  • The new dashboard dialog did not appear when selected from the dashboards menu
  • Changed the “Save” dashboard icon to an “Exit” icon since the dashboard is not actually being saved
  • Updates to the device cards per user dcorsus (for video playing)
  • Show Last Change on device card can now be disabled
  • Fixed apostrophe in dashboard name not allowing dashboard to be displayed
  • Forecast card now auto updates every hour
  • Added edit menu for Row-Col layout
  • Added a note about changing layouts and losing card order
  • Fixed an error message when selecting a dashboard that does not exist
  • Fixed typos in bulk edit menu
HS4 Changes from 4.2.22.4 to 4.2.22.27
New Feature
See the documentation related to the new dashboard features here.
Dashboards have been expanded to support custom dashboard cards. Custom cards may be provided by HomeSeer or third parties. New features include:
  • Multi feature card: display and control features from multiple devices
  • Status Icon card: Display just the status icon for a feature and control with a toggle
  • Status Text card: Display the status of a feature
  • Forecast Card: Display a 5 day forecast, uses the longitued and latitude that is set in HS for weather data
  • Text Card: Displays just text, useful for tagging groups of cards
  • Button Card: Display one or more buttons and assign an action to the button such as displaying another dashboard or running an event action
  • Notifications Card: Displays a list of notifications
  • Gauge Card: Displays a gauge that can be associated with a feature to display its value
New layouts
  • 4 layouts are available, row/col, masonry, masonry resizable, fixed resizable. Resizable layouts are new and allows for resizing cards. Fixed allows cards to placed at fixed locations and is usable for dedicated display such as a tablet.
Customizable Cards
  • All cards now have more customizable settings such as font sizes, font colors, background colors, background images, and more.
Key
Summary
HS-2068
Added support for custom dashboard cards and more dashboard display options
HS-931
On Linux, events scheduled to run at midnight would run multiple times
HS-1837
If feature one in a device is set as important and feature two is set as hidden, not last change time is displayed in the grid view
HS-2057
Allow adding device last change to device dashboard card
HS-2075
Add media folder to backups
HS-2080
On Linux HSSentry is not disabled when HS is shut down from the tools menu or an update
HS-2092
Allow configuration for WIFI on BPI board with updated Armbian OS (G8 units)
HS-2101
If a control pair label contains a control char, HSTouch may not display data properly
HS-2102
Web server requests getting corrupted causing broken or missing pages
HS-2103
Changes to the HSTouch speaker client user/pass in the setup are not honored
Windows
Linux
JavaScript errors detected
Please note, these errors can depend on your browser setup.
If this problem persists, please contact our support.
