DeviceTypeInfo Object
Purpose
The DeviceType object (DeviceTypeInfo) is accessed directly from the device class object using the _Get and _Set properties.   When a change is made to the DeviceTypeInfo object, _Set must be called to post the change to the device, and then hs.SaveEventsDevices should be called to force HomeSeer to save the device change.
Parameters
The prototype for the class is:
    Public Class DeviceTypeInfo
        Public Property Device_API As eDeviceAPI
        Public ReadOnly Property Device_API_Description As String
        Public Property Device_Type As Integer
        Public ReadOnly Property Device_Type_Description As String
        Public Property Device_SubType As Integer
        Public Property Device_SubType_Description As String
    End Class
Returns
Nothing
Example
Visual Basic
	Retrieve the DeviceTypeInfo object:
		Dim DT as DeviceAPI.DeviceTypeInfo = Nothing
		 ' The device has a reference ID of 1234
		dv = hs.GetDeviceByRef(1234)
		DT = dv.DeviceType_Get(hs)
		If DT IsNot Nothing Then
		End If
	Change the DeviceTypeInfo and Save the change
		Dim DT As DeviceAPI.DeviceTypeInfo = Nothing
Dim dv As Scheduler.Classes.DeviceClass = Nothing
If dv Is Nothing Then .... (log an error and exit the procedure)
			DT.Device_API = DeviceAPI.DeviceTypeInfo.eDeviceAPI.Plug_In
			dv.DeviceType_Set(hs) = DT
		End If
