Device_Type
Purpose
The Device_API should be set appropriately if the device is a part of an API, set to Plug_In if it is not a part of an API but is owned by a Plug-In, or set to No_API if it is not owned by a plug-in and is not a part of an API.  If the Device_API is set to an API type such as Thermostat or Music, then the Device_Type should be set to one of the API types for those APIs. (See DeviceTypeInfo Enums)
Parameters
The Device_Type property is an integer denoting the device type of an API, if any, that this device is a part of:
Public Property Device_Type As Integer
Returns
Example
Visual Basic
	(This sets the device to the thermostat API type "Mode Set")
	Dim DT As New DeviceAPI.DeviceTypeInfo
	DT.Device_API = DeviceAPI.DeviceTypeInfo.eDeviceAPI.Thermostat
	DT.Device_Type = DeviceAPI.DeviceTypeInfo.eDeviceType_Thermostat.Mode_Set
	dv.DeviceType_Set(hs) = DT
	hs.SaveEventsDevices
	(This sets the device to a plug-in custom type.)
	DT.Device_API = DeviceAPI.DeviceTypeInfo.eDeviceAPI.Plug_In
	DT.Device_Type = CInt(PlugDeviceType_X)
	DT.Device_SubType = 4
