eDeviceSubType_SecurityArea
Purpose
When the Device_Type is set to Security, and the security panel uses partitions/areas, the Device_SubType should be used to indicate the area number that the device belongs to IN ADDITION to there being a separate root/child device hierarchy per area/partition.   When areas/partitions are NOT used, the Device_SubType can be any integer value, but to avoid misinterpretation, it is suggested that values below 20 not be used.
Parameters
<Serializable()> _
Public Enum eDeviceSubType_SecurityArea
    Invalid = 0
    PRIMARY = 1
    Area_Partition_2 = 2
    Area_Partition_3 = 3
    Area_Partition_4 = 4
    Area_Partition_5 = 5
    Area_Partition_6 = 6
    Area_Partition_7 = 7
    Area_Partition_8 = 8
    Area_Partition_9 = 9
End Enum
Returns
Nothing
Example
Visual Basic
None
