Setting Up the ESPHome Plugin
Setup guide for the HS ESPHome software plugin
The plugin is designed to allow HomeSeer HS4 to monitor and control ESPHome devices. ESPHome is an open-source system that lets you create custom firmware for ESP32 and ESP8266 boards without writing any code, using simple YAML configuration files.
Compatible Devices
Any device running an ESPHome firmware is compatible. You can flash ESPHome firmwares to compatible available devices, or create your own from scratch using supported microcontrollers (ESP32, ESP8266, BK72xx, RP2040 and others).
HomeSeer Hub or HS4 Software
Setup
Go to Plugins > HS ESPHome > Manage Devices and click “Add ESPHome Device”. Enter:
  • the IP Address of your ESPHome device
  • the native API port , default is 6053
  • the encryption key as it appears in the api section of your YAML config file, or leave it blank if it does not use encryption
Click Add, the plugin will try to connect to the device, and if successfull it will create a HS Device corresponding to the components of your ESPHome device. Here is the device created for the example .yaml file that you can find below.
Creating your own ESPHome device
This example shows how to create and flash ESPHome firmware on a device. We will create a simple firmware for the ESP8266 NodeMCU microcontroller that lets you turn the onboard LED on or off, restart the device, and monitor an uptime sensor.
  • First you need to install ESPHome on a Windows, Linux or Mac computer using this guide.
  • To get a nice web interface you also need to install and start the ESPHome Device Builder (a.k.a dashboard)
    # Install dashboard dependencies
    pip install tornado esptool
    # Start the dashboard
    esphome dashboard config
  • Go to http://localhost:6052 to open the dashboard. Click “New Device” then select “New Device Setup.”
  • Enter a name for your device and your WiFi credentials. When prompted to connect to your device, click “Skip This Step.” Then select your device type; here, we use ESP8266.
  • Click “Skip” again when prompted to install the configuration on your device.
  • Edit the configuration you just created to fit your needs. In our example, we added the web_server component, an uptime sensor, a restart button, and a light component that controls the NodeMCU's onboard LED:
    esphome:
      friendly_name: ESP8266 Test
    esp8266:
      board: nodemcuv2
    # Enable logging
    logger:
    # Enable API
    api:
      encryption:
        key: "77G/P4l1hdaNRi0TA5+bhYtCJOk0KjzP4QO55GLqVIw="
    # Enable web server
    web_server:
      port: 80
    sensor:
      - platform: uptime
        type: seconds
        update_interval: 30s
    output:
      - platform: esp8266_pwm
        pin:
          number: D0
          inverted: true
    light:
     - platform: monochromatic
       output: onboard_led
    button:
      - platform: restart
    ota:
      - platform: esphome
        password: "4908cb1286ce87467502f6c08562dd52"
    wifi:
      ssid: !secret wifi_ssid
      password: !secret wifi_password
      # Enable fallback hotspot (captive portal) in case wifi connection fails
      ap:
        ssid: "Esp8266-Test Fallback Hotspot"
        password: "JibrAvDfFU9R"
    captive_portal:
  • Save, connect your device to a USB port on your computer, click Install, select “Plug into the computer running ESPHome Device Builder,” and choose the correct serial port for your device. Wait while the firmware compiles and flashes to your device. If successful, you should see this:
  • Click “Stop” to disconnect from the device, then click Visit to open the device's web interface. There, you can control the onboard LED, restart the device, and watch the Uptime sensor update every 30 seconds.
  • The last step is to connect it to the HS ESPHome plugin as explained in the Setup section
