WS300 Quick Start Guide
Use this guide to install the WS300 and to include it in your Z-Wave network.
The HomeSeer WS300 Smart Wall Switch is a Z-Wave in-wall switch that provides local and remote control of lighting and other loads. It installs into a standard wall box and works with single-pole or 3-way circuits.
Before You Begin
WARNING: Risk of fire, electrical shock, or burns. Do not use this switch to control devices that could create a hazard if operated remotely or unattended. Do not use with medical or life-support equipment.
CAUTION: To prevent overheating or equipment damage, do not exceed the maximum rated load.
IMPORTANT: Verify that power is off before touching any wiring. If you are unsure about wiring, consult a licensed electrician.
  • Neutral wire required
  • 120V AC lighting circuit
  • Compatible Z-Wave controller or hub
  • Single-pole or 3-way switch wiring
Tools Needed
  • Flathead screwdriver
  • Phillips screwdriver
  • Wire cutter / stripper
Wiring Overview
The WS300 requires the following connections:
Terminal
Typical Wire Color
Function
LINE
Black
Incoming power
LOAD
Black
Power to light/device
NEUTRAL
White
Neutral wire
GROUND
Green or bare
Ground connection
TRAVELER
Red or other
Used in 3-way circuits
Wire colors may vary. Use a multi-meter if necessary to confirm connections.
Installation Steps
If installing into a 3-way circuit, be sure to review the WS300 Wiring Guide first before proceeding! That guide discusses 3-way switch types and typical wiring practices.
  1. Turn OFF power at the circuit breaker before installing the switch and verify the power is off.
  2. Remove the existing wall plate and mounting screws.
  3. Pull the existing switch out of the electrical box.
  4. Identify and label the existing wires.
  5. Disconnect the wires from the old switch.
  6. Strip about 5/8 in (16 mm) of insulation from each wire.
  7. Insert each wire into the appropriate WS300 screw terminal and tighten securely.
  8. Carefully place the switch back into the electrical box.
  9. Attach the wall plate.
  10. Restore power at the breaker.
Adding the Switch to a Z-Wave Network
WS300 may be added to your Z-Wave network in two ways. Use the method that works best for your hub and situation.
  • Method 1 (compatible with all Z-Wave hubs)
    1. Put your Z-Wave controller into inclusion mode.
    2. On the WS300 paddle perform this sequence:
      1. Tap DOWN twice, then PRESS & HOLD DOWN (↓↓▼).
        The LED indicator will blink magenta during the inclusion process.
  • Method 2 (SmartStart inclusion)
    • Initiate the SmartStart procedure specific to your hub
    • Scan or manually copy the SmartStart code from the sticker on the switch
    • Add the device to your hub
    • Power the device.
      The switch will automatically join the network within a few minutes when powered near the controller.
Removing the Switch to a Z-Wave Network
  1. Put your Z-Wave controller into exclusion mode.
      The LED indicator will blink magenta during the exclusion process.
Local Switch Operation
  • Tap top of paddle: Turn load ON
  • Tap bottom of paddle: Turn load OFF
The switch may also be controlled remotely by any compatible Z-Wave hub.
Factory Reset (If Needed)
Use only if the Z-Wave controller is unavailable.
  1. Tap UP 3 times, then DOWN 3 times quickly
  2. If the LED blinks three times, the reset was successful.
Need More Information?
Full documentation and advanced configuration:
