HSM200 Quick Start Guide
Use this guide to get started with your HSM200.
What’s in the Box
  • HSM200 Z-Wave multi-sensor
  • Quick reference / documentation card
Setup (universal)
  1. Plug In the HSM200
    1. Remove the HSM200 from the packaging.
    2. Plug the sensor into a standard 120V wall outlet.
    3. Once powered, the RGB LED may illuminate briefly depending on its current Z-Wave status.
  2. Add HSM200 to Your Z-Wave Network
    1. Open your hub’s app or interface and place it into Z-Wave inclusion mode.
    2. Press the small button located on the side of the HSM200.
    3. The LED will blink blue rapidly while inclusion is in progress.
    4. Wait for your hub to confirm that the device has been added successfully. After inclusion:
      • The LED will blink white when motion is detected during the 5-minute test mode.
      • After 5 minutes, the sensor will enter normal operating mode and the LED will turn off.
      • Pressing the side button again restarts the motion test mode.
  3. Verify Device Features
    1. After inclusion, your hub should display the following features. If some features are missing, check with your hub manufacturer to confirm HSM200 compatibility.
      • Motion sensor
      • Temperature sensor
      • Light / luminance sensor
      • RGB LED control (supported hubs only)
  4. Quick Motion Test
    1. Walk within range of the sensor (approximately 12 feet).
    2. The LED should blink white when motion is detected.
    3. Stop moving and wait for the motion timeout period (default: 10 minutes).
    4. Verify that your hub updates the sensor status correctly.
SmartStart Setup (Optional)
The HSM200 may also be included into your smart home system using Z-Wave SmartStart.
  1. Open your hub’s SmartStart provisioning interface.
  2. Scan the QR code located on the back of the HSM200.
  3. Plug in the device.
  4. The hub should automatically add the sensor within several minutes.
Troubleshooting
Exclude the HSM200
If inclusion fails, perform an exclusion first.
  1. Put your hub into Z-Wave exclusion mode.
  2. Press the button on the side of the HSM200.
  3. Wait for the hub to confirm exclusion.
Factory Reset
Only use this procedure if the original Z-Wave controller is unavailable.
  1. Press and hold the side button for 60 seconds.
  2. The LED will blink blue, then yellow.
  3. When the LED turns off and then blinks cyan, the device has been reset and is ready for inclusion.
Factory reset clears all Z-Wave network information and configuration settings.
Notes
  • The HSM200 is powered directly from a wall outlet and also functions as a Z-Wave repeater.
  • The RGB LED can be controlled by compatible hubs using Z-Wave Color Control commands.
  • Default reporting intervals for temperature and luminance are 60 minutes.
  • Motion timeout and reporting intervals may be customized using Z-Wave parameters.
