HS4 Release 4.2.24.0
Manual Install
Windows
Linux
Download HS4 Windows
Download HS4 Linux
  2. Click the INSTALL UPDATE or INSTALL BETA button (depending on the release type).
  3. Follow the directions that appear. This may take several minutes to complete.
Changes from 4.2.23.0 to 4.2.24.0
Highlights
  • This release focuses on usability with the update HomeSeer mobile app. The update mobile app is now available for Android. Search the Play Store for “HomeSeer”.
  • Dashboard card enhancements - usability
  • Database optimizations - faster, more secure
  • Energy monitoring changes - stability and reliability
  • Linux tools improvements
  • Permissions improvements
Full Change List
  • Changes throughout the UI to better support mobile screens
  • Added better support for screen readers
  • Added ability to add custom device names to multi-feature dashboard card
  • When searching for features on the multi-feature card, non matches are set as hidden
  • Added a better solution for checking the password in Linux Tools, this should now function on any version of Linux
  • Camera recordings folder was not getting pruned unless recordings page was viewed. This was causing disk to fill. Pruning now happens once a day.
  • On Linux based systems, the Linux Tools menu now gives access to a full terminal.
  • Fixed some errors when calculating disk space for backups.
  • Updated shop page to allow HS4 Legacy plugins to appear in the Legacy section.
  • Fixed issue where dashboards were created with user id 0 when the user login name was capitalized.
  • Optimizations to SQLite database
  • Added “uncheck all” to device list on energy page
  • The selected list of devices in the energy page device list is now saved
  • Fixed usage/cost radio controls on energy page
  • Added ability to cycle through dashboards using mobile app
  • Disabled bulk edit for non admin users
  • Added setup option to report all devices to HSTouch regardless of device visibility setting
  • ​If a user does not have access to a feature, the navigation menu will omit that feature
  • Fixed device sorting Asc/Desc so its sorts second location alphabetically
  • Fixed select image file picker on dashboard settings so it appears in front of settings dialog
Windows
Linux
