Z-NET PRO Quick Start Guide
Use this guide to get started with your Z-NET PRO.
What’s in the Box
  • Z-NET PRO interface
  • AC power adapter + cable
  • Ethernet cable
  • Quick Start card
Steps
  1. Unbox & Power Up
    1. Take everything out of the box.
    2. Connect the Ethernet cable from your router (or network switch) to the Ethernet port on the Z-NET PRO.
    3. Plug USB-C power cable into the Z-NET PRO and the other end into the AC adapter.
    4. Plug the AC adapter into power.
    5. The top LED will glow red briefly then green once powered up.
  2. Access the Web Interface
    1. On any computer/phone on the same network, open a browser and go to HomeSeer System Finder
    2. You should see a link for the Z-NET PRO. Click it to open the settings page. If the page opens successfully, congratulations! Your Z-NET is now connect to your network. If you’ll be using a wired Ethernet connection (recommended), skip to Next Steps below.
  3. (Optional) Connect via Wi-Fi (Use this only if you can’t use wired Ethernet)
    1. On the Z-NET PRO settings page, find the Wi-Fi selection section.
    2. Choose your Wi-Fi network from the list.
    3. Enter:
      1. SSID (network name)
      2. Encryption type
      3. Wi-Fi password
      4. Click Connect.
      5. Status, IP address, and MAC address will be shown once connected.
Next Steps
Now that your Z-NET PRO is connected to your local network, it’s time to find the best location for it and integrate it with your hub. Refer to the docs linked below for help with finishing your setup and installation.
