Z-NET PRO Hardware Features
This guide covers the hardware features of the Z-NET PRO
Front Panel
  • LED status indicators
    • Power: The top LED glows red for a few seconds when first plugged in, then changes to green to indicate the unit is operational. This LED will remain lit as long as the unit is operational.
    • Z-Wave: The middle LED glows green when Z-Wave is correctly configured to work with your hub. Otherwise it is off.
    • Zigbee: The bottom LED glows green when Zigbee is correctly configured to work with your hub. Otherwise it is off.
Bottom Panel
From left to right…
  • Push button: Use this to restart the unit or to perform a factory reset.
    • Press for 1-3 second to initiate a restart of the Z-NET PRO. The LEDs will turn off, then turn back on again starting with the power LED.
    • Press for 10 seconds to initiate a factory reset of the Z-NET PRO. The LEDS will blink rapidly. Release the button when the LEDs stop blinking.
      • This function resets the Z-NET PRO Name and WiFi settings. No other data is affected.
  • Power port: Connects to the included USB-C power cable to power the unit.
  • Ethernet port: Used to connect Z-NET PRO to your router or network switch.
