Documentation for the HomeSeer network connected Z-NET PRO Z-Wave & Zigbee controller.
The Z-NET PRO is a Z-Wave & Zigbee radio network-connected interface that’s designed to be used with HomeSeer, Home Assistant, and openHAB smart home hubs. It supports the Zigbee 3.0 protocol and the latest 800 series Z-Wave mesh and long range technologies. Use the guides below to install and configure it for your system. Note: It is not a stand-alone smart home hub.
IMPORTANT: We want you to be happy with your HomeSeer experience. If you’re having trouble getting your Z-NET PRO up and running, start here:
Email support@homeseer.com for product technical support.
Email sales@homeseer.com for order help or pre-sales questions.
Z-NET PRO Quick Start Guide Use this guide to get started with your Z-NET PRO.
Z-NET PRO Positioning Guide Use this guide to help determine the best location for your Z-NET PRO
Z-NET PRO Web UI & Settings Use this guide to access and edit Z-NET PRO settings
Z-NET PRO Hardware Features This guide covers the hardware features of the Z-NET PRO
Z-NET PRO IP Address Reservation Guide Use this guide to set an IP address reservation for your Z-NET PRO
Z-NET PRO Integration with HomeSeer Use this guide to configure your HomeSeer hub to work with the Z-NET PRO Z-Wave & Zigbee network interface using Z-Wave Plus and Zigbee Plus plugins.
Z-NET PRO Integration with Home Assistant Use this guide to configure your Home Assistant hub to work with the Z-NET PRO Z-Wave & Zigbee network interface using Z-Wave JS, Z-Wave JS UI and Zigbee Home Automation (ZHA) integrations.
Z-NET PRO Integration with openHAB Use this guide to configure your openHAB hub to work with the Z-NET PRO Z-Wave & Zigbee network interface.
Z-NET PRO Integration with Zigbee2MQTT Use this guide to configure your hub to work with the Z-NET PRO Z-Wave & Zigbee network interface using Zigbee2MQTT.
Z-NET PRO Migrating from Another Controller Use this guide for migrating from a 500 or 700 series Z-Wave interface to an 800 series interface (SmartStick G8, Z-NET G8 or Z-NET PRO)
Z-NET PRO PoE Installation Guide Use this guide to connect a Z-NET PRO to a PoE (Power over Ethernet) network
Z-NET PRO Troubleshooting Guide Use this guide for help with issues
Z-NET PRO Specifications Specs for the Z-NET PRO
Z-NET PRO Z-Wave Firmware Updates Information on updating the Z-Wave SDK firmware on the Z-NET PRO Z-Wave network adapter
