HS4 Beta Release 4.2.23.10
As with all Beta releases, make sure you back up your system before installing this Beta!
Manual Install
Windows
Linux
Download HS4 Windows
Download HS4 Linux
HS4 Changes from 4.2.23.9 to 4.2.23.10
  • Fixed typo on bulk edit command list
  • On log page, increased padding around export button
  • Added setup option to report all devices to HSTouch regardless of device visibility setting
HS4 Changes from 4.2.23.7 to 4.2.23.9
  • ​If a user does not have access to a feature, the navigation menu will omit that feature
  • Fixed long device address strings without spaces displaying outside card
  • Fixed incorrect icon displaying for grid/list button
  • Fixed log page buttons getting cut off, moved auto update and  export buttons to a second row
  • Changed Android App menu form "Application Settings" to "Application Login"
  • When clicking off the navbar hamburger menu, the screen would not unblur
  • Fixed pull-to-refresh causing navbar scrolling to refresh page
  • Removed remaining HS3 pages/code
  • Mobile updates to dashboard settings dialog: replaced text on buttons with icons, fixed delete button not displaying confirmation dialog, moved label on layout droplist, removed debug alert
  • Fixed energy graphs not displaying
  • Updated sqlite to the latest
HS4 Changes from 4.2.23.0 to 4.2.23.7
  • UI Changes for better display on mobile devices
  • Updates to pages: timers/counters,log,devices,help
  • Added “Application Settings” link to mobile menu to access HomeSeer Mobile main page
  • Dashboards can now be edited on mobile devices
  • Fixed device sorting Asc/Desc so its sorts second location alphabetically
  • Fixed select image file picker on dashboard settings so it appears in front of settings dialog
  • Disabled processing of custom card button actions when card is in edit mode
  • Devices page now collapses filters to save space on mobile
  • Added ability to rename counters and timers
  • Swapped icon on grid/list button to show button action not status
Windows
Linux
