HS4 Release 4.2.19.0
Manual Install
Windows
Linux
Download HS4 Windows
Download HS4 Linux
  3. An Install Beta pop up appears. Click INSTALL to begin the installation. This may take several minutes to complete.
Feature Highlights
This version includes the following new features or enhancements
Real-Time Device Filter
Type into the ADD FILTER(S) field on the Devices page and your device list will instantly change to your filtered view. Filter tags may be combined to perform OR and AND searches and you can use can also filter based on device status!
New Event List Features
It's now possible to filter the Events list by device and group with 2 drop down selectors. You can use display a summary of triggers for each device to better understand and find events at a glance.
Event Hyperlinks in Log
When events run, their log entries are now hyperlinked, making if much easier to access events directly from the log.
Changes from 4.2.18.5
Key
Summary
HS-1851
Update PSDK to v1.4.4
HS-1807
Users report that events are lost after a power outage
HS-1230
Unable to download backups when connecting via MyHS
HS-1858
Show List/Show Grid buttons are not updated when clicked
HS-1877
Cannot set feature room or floor if location 1 is set to display first
HS-1867
Shorten registration process to get trial users into the program faster
HS-1870
Using bulk edit to change a devices location leaves the devices selected
HS-1865
Add ability to display summary trigger information on the events list page
HS-1862
Selecting ALL devices in filtered view selects devices that are not filtered
HS-1846
Add links to events from log
HS-884
Tool Tip for Feature behaves incorrectly once status icon changes
HS-1666
Use PluginSdk.Events.EventData instead of HomeSeerAPI.strEventData in HS Core
HS-1868
Create sample devices and events for trial users to work with
HS-1761
HsEvent is not raised at the end of a backup operation
HS-1853
Add ability to create events triggers and actions from device properties
HS-1776
Add support for Reolink cameras
HS-1861
The querystring on the devices page ?sortby=namedec is actually sorting name ascending
HS-1767
Add gwebsvrport=80 attribute to settings.ini by default
HS-1856
Allow quotes in devices chips searching to search refine search
HS-1859
Add support for sending email through office 365
HS-1857
Add querystring to set grid and list modes and show/hide marked
HS-1763
Add event searching by device/feature referenced to the UI
HS-1787
Shutdown script is running too late in the shutdown process. Can change the delay by setting ShutdownScriptWaitSecs in the settings.ini file.
HS-1592
Device does not always update in view
HS-1842
Backups are failing if thumbs.db file is present, backups include the backups folder if its named "Backups"
HS-1848
When using a querystring to filter devices existing filters are not reset
HS-573
Link Device List is not alpha sorted and contains a mixture of different carets/styles
HS-1733
Camera Issue: Pan Right Button does not stop panning when you let up on it
HS-1614
Clear Filter button does not work when filter is set to "refnum=" value
HS-1525
Add Buttons to All Camera Page
HS-1524
Individual Camera Page GUI Improvements
HS-1671
Enhance JSON controlbydevicevalue warnings
This build also includes an update plugin SDK version 1.4.4
Release Notes
Windows
Linux
