As with all Beta releases, make sure you back up your system before installing this Beta!
Manual Install
Windows |
Linux |
If you need to perform a new install or the update is not available through setup, run the installer |
For standard Linux tar file, check in setup for an update, or manually update with the TAR file |
Navigate to Setup > General and click the CHECK UPDATE button.
Click the INSTALL BETA button.
An Install Beta pop up appears. Click INSTALL to begin the installation. This may take several minutes to complete. Your controller or computer will restart after the installation completes.
HS4 Changes from 4.2.23.18 to 4.2.23.19
Fixed installer not installing the SQLite DLL properly
HS4 Changes from 4.2.23.12 to 4.2.23.18
Added a fix to avoid SQLite conflicts with some plugins. All plugins should load properly. (fixes issue created with 4.2.23.12)
Optimizations to SQLite database
Made “kWh” labels consistent
Added “uncheck all” to device list on energy page
Added “Deleted” tag to devices in energy list if device no longer exists
The selected list of devices in the energy page device list is now saved
Fixed usage/cost radio controls on energy page
HS4 Changes from 4.2.23.11 to 4.2.23.12
Added ability to cycle through dashboards using mobile app
Fixed edit buttons on timers/counters page
Fixed button alignment on timers/counters page
Disabled bulk edit for non admin users
Restored HS3 device config page for HS3 plugins
HS4 Changes from 4.2.23.10 to 4.2.23.11
Fixed error message when opening a page on IOS
Added a log message when a plugin is uninstalled
HS4 Changes from 4.2.23.9 to 4.2.23.10
Fixed typo on bulk edit command list
On log page, increased padding around export button
Added setup option to report all devices to HSTouch regardless of device visibility setting
HS4 Changes from 4.2.23.7 to 4.2.23.9
If a user does not have access to a feature, the navigation menu will omit that feature
Fixed long device address strings without spaces displaying outside card
Fixed incorrect icon displaying for grid/list button
Fixed log page buttons getting cut off, moved auto update and export buttons to a second row
Changed Android App menu form "Application Settings" to "Application Login"
When clicking off the navbar hamburger menu, the screen would not unblur
Fixed pull-to-refresh causing navbar scrolling to refresh page
Removed remaining HS3 pages/code
Mobile updates to dashboard settings dialog: replaced text on buttons with icons, fixed delete button not displaying confirmation dialog, moved label on layout droplist, removed debug alert
Fixed energy graphs not displaying
Updated sqlite to the latest
HS4 Changes from 4.2.23.0 to 4.2.23.7
UI Changes for better display on mobile devices
Updates to pages: timers/counters,log,devices,help
Added “Application Settings” link to mobile menu to access HomeSeer Mobile main page
Dashboards can now be edited on mobile devices
Fixed device sorting Asc/Desc so its sorts second location alphabetically
Fixed select image file picker on dashboard settings so it appears in front of settings dialog
Disabled processing of custom card button actions when card is in edit mode
Devices page now collapses filters to save space on mobile
Added ability to rename counters and timers
Swapped icon on grid/list button to show button action not status
Windows
Uninstall the beta. Do not remove HS4 settings and temporary files.
Install the previous version.
Launch HS4 and navigate to Setup > General and click Edit Config
Select the config file that was created when the beta was installed. The name will contain _before_4.2.x.x.json
Check your events to confirm they're all there and the actions are correct
Linux
Navigate to Setup > General and click REINSTALL UPDATE
Once installation is complete, navigate to Setup > General and click Edit Config
