As with all Beta releases, make sure you back up your system before installing this Beta!
Manual Install
Windows |
Linux |
If you need to perform a new install or the update is not available through setup, run the installer |
For standard Linux tar file, check in setup for an update, or manually update with the TAR file |
Navigate to Setup > General and click the CHECK UPDATE button.
Click the INSTALL BETA button.
An Install Beta pop up appears. Click INSTALL to begin the installation. This may take several minutes to complete. Your controller or computer will restart after the installation completes.
HS4 Changes from 4.2.24.6 to 4.2.24.10
Removed “test” text from plugins page
When view a device feature (from devices view), a devices setting link has been added that links to the main device settings
Remove history settings from HS4 root devices, which have no value or status to record.
Show history toggles in blue for the selected choice and grey for the others.
Move the Tools > History device picker onto the Devices line, with a Select button beside it and at the bottom of the list.
Show history values with the regional decimal and thousands separators.
Add a CSV download of a device's changes and use icon buttons for the history pager.
Show a history icon on the Devices page for features that record history.
Updates to some pages for screen readers
Fix downsampled history graphs drawing values at times they were never recorded.
Add a Tooltip graph setting, hidden by default and never shown on phone-sized screens.
Fit history graph margins to their axis labels and widen the graph on phones.
Let vertical swipes on a history graph scroll the page on touch screens.
Add a per-device valid range to Graph Settings and let admins delete single records from the Changes table.
Show the state in history crosshair labels, name timelines under their bands, and wrap a left-aligned device legend shown whenever more than one device is charted.
Update HSConsole exe file to reference new SQLite dll in sqlite folder for Linux
Changed plugin and notifications updates to access the server in the background so the web site does not lock up
Changes to INI file access so a failed read does not write an empty file
Fix for notifications page displaying a scriban error if updates file was empty
Fix MyMkDir doubling the HS path on Linux (empty <HS>/<HS>/html/<PluginId> folders created on plugin install)
Added plugindisable and pluginenable to the JSON API, one parameter, plugid
HS4 Changes from 4.2.24.0 to 4.2.24.6
Added support for device history logging and graphing
Fixed setup stuck on spinner when checking for updates
Return an error when a plugins postback throws and error
Fixed last change time on device cards in grid view now display the time the latest feature changed
Removed “Scene Activation” feature from JSON device status response. This was causing issues with Alexa and Google Home
On Linux, apps that use control keys, such as nano, now work properly in the Linux tools shell.
Windows
Uninstall the beta. Do not remove HS4 settings and temporary files.
Install the previous version.
Launch HS4 and navigate to Setup > General and click Edit Config
Select the config file that was created when the beta was installed. The name will contain _before_4.2.x.x.json
Check your events to confirm they're all there and the actions are correct
Linux
Navigate to Setup > General and click REINSTALL UPDATE
Once installation is complete, navigate to Setup > General and click Edit Config
