As with all Beta releases, make sure you back up your system before installing this Beta!
Manual Install
Windows |
Linux |
If you need to perform a new install or the update is not available through setup, run the installer |
For standard Linux tar file, check in setup for an update, or manually update with the TAR file |
Navigate to Setup > General and click the CHECK UPDATE button.
Click the INSTALL BETA button.
An Install Beta pop up appears. Click INSTALL to begin the installation. This may take several minutes to complete. Your controller or computer will restart after the installation completes.
HS4 Changes from 4.2.24.0 to 4.2.24.6
Added support for device history logging and graphing
Fixed setup stuck on spinner when checking for updates
Return an error when a plugins postback throws and error
Fixed last change time on device cards in grid view now display the time the latest feature changed
Removed “Scene Activation” feature from JSON device status response. This was causing issues with Alexa and Google Home
On Linux, apps that use control keys, such as nano, now work properly in the Linux tools shell.
Windows
Uninstall the beta. Do not remove HS4 settings and temporary files.
Install the previous version.
Launch HS4 and navigate to Setup > General and click Edit Config
Select the config file that was created when the beta was installed. The name will contain _before_4.2.x.x.json
Check your events to confirm they're all there and the actions are correct
Linux
Navigate to Setup > General and click REINSTALL UPDATE
Once installation is complete, navigate to Setup > General and click Edit Config
