Contains information on installing and updating HS4.
Updating HS4 Instructions on updating each possible instance of HS4.
Registering HS4 You'll need to register HS4 before you can use it. Here's how!
Web Server Startup Problems Start here if you encounter problems running HS4 after installation
Unable to Access System After Registration If you are unable to access your system after registration follow these instructions to regain control.
Quick Start Guide for HS4 The guide includes the basic steps necessary to get started with HS4 software.
