System (HS4)
Use this function to access operating system tools and functions.
System resources may be accessed by opening the Tools menu and selecting System.
System Options
Windows
Navigate to Tools > System > Restart System to restart your HomeSeer system.
Linux
The following options are available on Linux HS4 systems:
  • Shutdown HomeSeer… - Shuts down HS4 but does not shut down Linux.
  • Shutdown System… - Shuts down HS4 and Linux.
  • Restart System… - Restarts HS4 and Linux.
  • Linux Tools - Opens a command prompt for entering Linux commands. Use the Linux login, which is “homeseer” by default. If you created your own version of Linux, use the login you created.
  • Change System Password - Allows users to change the default Linux system password.
