HS4 Release 4.2.14.0
Changes
Key
Summary
HS-1662
When restarting HS from the tools menu or initiating an update, internal services should be shut down first
HS-1492
Enhance loading of Add and Manage Plugins pages by implementing lazy loading of icons
HS-1634
JSON inconsistencies for EvTrig_DEVICE_VALUE
HS-1658
When running as as a service a system shutdown/restart does not shut down HS properly
HS-1512
Order of feature pages different in two places in HS 4.2.7.0
HS-1675
Update EULA during software installation and on the About page
HS-1651
Thermostat card current temperature overlapping issue
HS-1672
Insteon fan controllers are not controlled properly with Alexa/Google
HS-1204
Cannot remove the last timer, counter, or event.
HS-1387
Event trigger Timers value adds a year if set to more than 182 days.
HS-1518
Featured plugins in the updater do not show if they are installed.
HS-1660
Chromecast plugin for HS4 when installed shows HS3 version to be installed also.
HS-1629
Link the up/down arrows on thermostat cards to actual controls
HS-1620
Add the ability for the UI to present web pages in a more condensed format
HS-1635
When selecting a new device in a "Device's Value is.." trigger old values are not reset.
HS-1648
When clicking on a date on the camera recordings page, the URL is incorrect for non-US date formats
HS-1650
Max Log Size Setting does not work
HS-1677
Long JUI input field label cover up the input itself
HS-1139
Page not refreshed after "Immediate Command" checkbox is changed
HS-1661
Font size is incorrect with Safari on the Mac and the compact stylesheet
HS-1615
Add device name at the top of the device plugin config tab
