HS4 Release 4.2.18.5
Installation
Manual Install
  • Windows
    If you need to perform a new install or the update is not available through setup, run the installer:
  • LinuxFor standard Linux tar file, check in setup for an update, or manually update with the TAR file:
  3. An Install Beta pop up appears. Click INSTALL to begin the installation. This may take several minutes to complete.
Windows
Linux
Changes from 4.2.18.3
  • When updating from HS3 to HS4 the import of the HS3 .HSD file would fail and not import events
  • Some EasyTrigger conditions do not work in conditional actions
