HS4 Release 4.2.22.0
Manual Install
Windows
Linux
Download HS4 Windows
Download HS4 Linux
  2. Click the INSTALL UPDATE or INSTALL BETA button (depending on the release type).
  3. Follow the directions that appear. This may take several minutes to complete.
Feature Highlights
  • Added support for dashboards, read more .
Changes from 4.2.21.2
Key
Summary
Added support for Dashboards. See the docs .
Removed 5 plugin limit on PI-HUB
Plugins page is not displaying when a beta update is available for a released plugin
If a beta plugin is installed and then released with the same version, it still shows as beta.
If an update (plugin or HS4) is detected on startup and triggers an event, the event actions may not execute if they belong to a plugin that has not finished initializing.
Events are no longer saved when HS4 is shut down. This reduces the possibility of corruption of the events datafile.
Added setup option to log all device changes and sets. Log includes links to device properties.
The “has additional data” option on the status graphics page is not able to be saved.
If a log entry contains the word “error” it is displayed in red, it should not do this.
Device control buttons now highlight the current status.
Notification icon will now update if a notification arrives and the page is not refreshed.
Devices cannot be controlled from results using the search box at the top of the page.
Windows
Linux
